It is currently Tue Jun 27, 2017 6:57 am
PostPosted: Wed May 22, 2013 10:35 am
I have recently acquired a Holder 12 sailboat made by Hobie Cat that is in excellent condition. At some point in time however, the upper mast was lost and I would like to find a replacement if anyone has one. Failing that, could someone please provide the upper mast specifications. The overall length, the outside diameter, the wall thickness/inside diameter of the mast. In addition it would be helpful to know the distance the collar is from the top of the mast. I am assuming the upper as went inside the lower mast up to the collar. With this information, hopefully I will be able to purchase a piece of aluminum tubing as a replacement. Surprisingly Hobie Cat was unable to provide this information and suggested this forum.
Thank you in advance for any help.
Tom
PostPosted: Wed May 22, 2013 3:38 pm
We have a drawing I can email to you. It will not have a lot of ID/OD dimensions... it is an assembly drawing. The upper has been aluminum and several different types of fiberglass. One fiber version was custom, the rest were cut from windsurf masts.
PostPosted: Wed May 22, 2013 6:12 pm
Thank you for sending the drawings. Although they do not provide the OD/ID dimensions, they are a big help and will enable me to fabricate a replacement upper mast in the likely event that I cannot locate a used one.
Tom Myatt
