It is currently Fri Mar 24, 2017 8:29 am
PostPosted: Tue Oct 01, 2013 11:32 am
I made a royal hash of my bottom job - I didn't get all the gelcoat off the bottom before applying the new fiberglass tape. I was using a 5" orbital sander and it just didn't seem to make any headway with 80 grit paper on the gelcoat.
So two questions:
1) Any recommendations for what kind of sander will do a better job getting the gelcoat off? (I also need to sand off dripped polyester resin). Please suggest specific models - I need something with more guts I'm guessing.
2) Do I need to remove the fiberglass tape I applied over partially-removed gelcoat? Or do I just leave it on and add more over it?
Broward County, FL
1984 Hobie 16, Olympic Edition (kept in NY)
PostPosted: Tue Oct 01, 2013 3:21 pm
So two questions:
Best choice is an air-powered one - that way the dust doesn't eat up the brushes in the electric motor.
Pros use a angle sander:
But you've got to be really gentle with it. It will tear up the boat if you're not careful.
PostPosted: Wed Oct 02, 2013 1:26 pm
As much as I have done, I rarely use a power sander for removing material on a Hobie. To remove gelcoat, I use one of these:
http://www.autobodytoolmart.com/hutchin ... 11982.aspx
with a variety of coarse sandpaper. It goes right through, and most of the junk removes falls straight down. I use a lot of pressure and not a lot of speed. More like using a file.
36 grit rubs gelcoat right off: http://www.nortonautobodysandpaper.com/ ... -of-50/ea/
Durablocks with PSA to get close enough for final squeegee coat, and sanding with wet-or-dry to get to the point that it's ready for spraying gelcoat. Durablocks come up to about 3 feet long. PSA sandpaper comes in rolls, so you cut length to fit whichever block you use. The Durablocks flex some, but not enough to allow digging dips like you can by hand. http://www.autobodytoolmart.com/dura-bl ... 11890.aspx
It's hard to do a professional quality job quickly without spending some money on good tools. http://www.autobodytoolmart.com/dura-bl ... 16007.aspx
PostPosted: Wed Oct 02, 2013 6:19 pm
MBounds wrote:
So two questions:
Hi Matt, I'm wondering what the difference is between the angle sander in your picture and what I have pictured below. I used this Makita GV5010 5" disc sander last summer when I painted my house and I have to say it is quite possibly the best tool I have ever purchased. It is extremely light weight, has a semi-flexible backing pad and can be used with discs ranging from 20 grit all the way up to 120 grit or more. I agree you would want to be extremely careful using it on a boat. That said, I was surprised by the amount of control I had using this sander my house (I thought it would be digging in and jumping around all over the place but that wasn't the case). Anyways, a fantastic tool. The 50 and 80 grit discs were magic on my house. :D
PostPosted: Wed Oct 02, 2013 7:29 pm
^ Probably not much diffrence except in the form factor. Maybe a modest difference in price (I have a cheap one that I use mostly for compounding/finishing - not a Makita).
