It is currently Mon Jul 15, 2019 6:04 pm
 Post subject: Hobie 16 mast repar
PostPosted: Fri May 04, 2018 3:15 am
Mast came apart at mast tag. Compit looks okay. Will ha ve to cut mast & lower tang.
Shorten mast by 7in. What about wires & sail?
 Post subject: Re: Hobie 16 mast repar
PostPosted: Fri May 04, 2018 9:05 am
You're asking for a lot of aggravation shortening the mast by 7". All of the rigging will likely have to be replaced with custom lengths, jib may not even have enough clearance to hoist all the way, foot of the mainsail will be practically dragging on the tramp. You would be much better off sourcing a new (used) replacement. They tend to pop up fairly often on craigslist.
PostPosted: Mon May 07, 2018 6:45 am
its the new H16 deck sweeper main....
Catamaran Racing Association of Michigan - Marketing Officer
US Sailing Multihull Championship Committee
F18 Hobie Tiger
Hobie 16 - BREAKPOINT
PostPosted: Tue May 15, 2018 8:24 am
Cutting the mast by 7" seems like a lifetime of frustration. Everything from wires to sails to racing handicap will be affected. Even if you manage to get everything set correctly, your boat will be considerably underpowered compared to others. You'd never be able to keep up.
Perhaps you can find someone selling a junk 16 and salvage the mast?
