It is currently Sat Jan 20, 2018 5:32 am
 Post subject: Glueing Comp-tip
PostPosted: Sun Apr 25, 2004 7:18 pm
What type of glue/cement should I use to fasten the comp-tip to my mast? The guy I bought it off of didn't glue it. Does it need it be glued??
Thanks!
PostPosted: Mon Apr 26, 2004 5:19 am
I just got done putting a comp tip on my 16. I used a two part epoxy from west marine. A tooth brush works well for application.
Remember that when you apply the epoxy to the extrusion and comptip that the epoxy will initially act as a lubricant. ( so don't take too much off in the dry fit process)
