It is currently Mon Dec 18, 2017 11:53 am
PostPosted: Mon Jun 14, 2004 12:46 pm
I read some of the previous posts regarding hull delam repairs and know how to do it, but I was curious to know if anyone had ever used "Boat Yard Fiberglass Resin" by Evercoat Marine? I know that West Systems is the best, but I'm guessing that my hulls will take 2 quarts of the stuff (since so much of the area is soft) and that'll put me in the neighborhood of $80-$100. And the Git Rot stuff is even a bit more expensive. So, I picked up a gallon of this other stuff for $20 at Boater's World. Of course, nobody there has any better clue of how to use the stuff than I do (most of the time they simply read aloud the directions from the can to me. "Thanks, that was very helpful." :roll: )
I'm just concerned that this polyester resin will harden too quickly or that it won't harden at all without the proper matting. And advice? Thanks!
-Mark
 Post subject: Which resin?
PostPosted: Mon Jun 14, 2004 3:04 pm
I prefer the Git-Rot because it is somewhat flexible when hardened. Some resins will be too hard and crack when loaded or when you step on the deck.
You might be surprised at how little resin is used with the injection repair. It is like pages in a book. There is little gap between the layers. You can force the layers apart by injecting too much resin and it will not be as strong. I might even recommend injecting a number of areas in a pattern that can pre-bond the layers so the lower (inside) layer doesn't sag as much while doing the major amount of injecting.
PostPosted: Mon Jun 14, 2004 3:43 pm
Is the West Systems resin flexible like the Git-Rot? I had planned on injecting the resin in a few strategically placed holes on the hull tops. Thanks for the reply!
-Mark
