It is currently Sat Nov 18, 2017 7:15 pm
PostPosted: Fri May 22, 2009 5:18 pm
81410011 MirageDrive Well Retrofit (For Outbacks and Adventures only). Outbacks [older] than July of 2003 would not use the bolts part of the kit.
Extended Warranty Coverage
Our normal two-year warranty coverage for Outback and Adventure hulls will be extended to four years with 100% coverage for damage to the well on kayaks in the specified range. After four years there will be pro-rated coverage on those hulls for an additional two years.
Outbacks with serial numbers A3753 through F2853
Adventure with serial numbers D0001 through D1875
Kit includes:
Sandpaper
Alcohol Swab
Molded fiberglass fitting
Loctite Epoxy Pack
(2) new knobs (in case of some damage)
(2) longer bolts (tapered ends)
5/16" allen wrench
Instructions
Here is the instruction:
Hobie Mirage Outback and Adventure drive well strengthening kit.
Note: This complete kit may not be needed for older Outback models due to the length of the camlock knob bolts. Outbacks built before August of 2003 (Serial number 3753) should not need the longer bolts. Those boats would have appropriate bolt lengths. Boats built after that serial number are suspect due to a change in the mold shape.
It has come to our attention that the camlock knobs can flex out of column under heavy loads. This may allow the knobs to ratchet.
