It is currently Fri Nov 17, 2017 9:47 pm
 Post subject: Covering your Getaway
PostPosted: Wed Jul 08, 2009 6:30 pm
I would like to know how everyone covers their Getaway. I store mine on a trailer with the mast up. The wings, trapeze, and stays make it a pain to cover. Any ideas I would love to hear your suggestions. I just want to keep it dry and the UV rays off of it.
PostPosted: Thu Jul 09, 2009 1:13 am
a couple of tarps attache with bungee cords work fine for me.
1 8x10 to cover the main tramp.
1 8x6 to cover the front.
I just detach the trapeze, since they are in the way.
PostPosted: Thu Jul 09, 2009 6:51 am
Do you have problems with water puddles on the tramp?
PostPosted: Thu Jul 09, 2009 6:55 am
no, not really. there is water puddle after rain but that does not seem to be a big deal.
PostPosted: Fri Jul 10, 2009 9:10 am
I do the same thing with the tarps, silver side up to reflect heat. We have had extemely wet weather this year, so I cut slots in the tarps at the low spots for drainage. Has worked well so far.
PostPosted: Fri Jul 10, 2009 9:54 am
Also, last year I used the cheap blue tarp, and while it did the job, UV still when through.
This year I switched to UV resistant tarps, slightly thicker and more expensive.
PostPosted: Fri Jul 10, 2009 11:52 am
A 6x8 silver tarp cut in half covers the wings
Brooks
PostPosted: Fri Jul 10, 2009 7:32 pm
I bought one those cheap portable single car garage's, its just long enough to back the whole boat and trailer into. Best thing it was only 149 bucks at costco.
PostPosted: Sun Jul 19, 2009 8:07 pm
Cut semi circle slits in the tarp, you are tarping to protect from UV, let the water through. 9 per tarp should do.
Frank, sailing '02 Getaway in Wichita KS. Lake Cheney
(Hobie 17 RIP, storm of '05)
PostPosted: Tue Oct 06, 2009 4:44 pm
Well after 6 years of letting my getaway sit uncovered in the sun in Florida, the covers on the wings are deteriorating (and I replaced the front tramp once about 2 years ago). Before I replace the wing covers, I was wondering if anyone had tried anything different for covering the wings, such as EVA foam glued to the wings. I think this is the type of foam used for the "seats" on the Hobie Wave and it is also used as a non-skid deck on some windsurfers. If I go this route, any idea of where to buy this stuff? Quick internet search yielded a supplier from Taiwan, but minimum order is one full 20' shipping container.
Cheers,
paul
PostPosted: Thu Oct 08, 2009 6:36 pm
I wrap each wing with 2 of the large contractor trash bags from the home depot, these are heavy duty bags and have lasted all season long. I keep the bags secured to the wings by wraping them with some nylon rope. This has worked very well for me this season. It's not very pretty but it works. I will post a photo when I get up to put my boat away for the season.
PostPosted: Mon Oct 19, 2009 6:18 pm
why don't you just take the two large Phillips screws out from each end of the wings that mount to the adjustable supports
and swing the wings down beside the hauls this will allow on large tarp to cover the hole cat ,and if your trailer has a forward and rear mast support you can use the mast to tent the tarp over the cat hauls ,the tarp sides will be sloped sloped for the snow and rain slide off. I think the tarp I used is heavy duty silver 24'x12' and 20 x long rubber truck bungees. This worked great for three seasons so far.
