It is currently Tue Jan 23, 2018 7:41 am
PostPosted: Wed Jul 06, 2005 6:09 am
I WANT TO ATTACH MY RIGHTING POLE TO THE FRONT MAIN BEAM.
CAN I DRILL A HOLE THRU THE ENTIRE BEAM,FRONT TO REAR, WITH S.S. BOLTS,TO ATTACH THE SUPPORT BRACKET, WITHOUT DAMAGING ANYTHING (INNER STRUCTURE)???
 Post subject: Forward beam
PostPosted: Fri Jul 08, 2005 10:29 am
The beams are hollow. We do the same for mounting the seats. No problem.
PostPosted: Mon Feb 06, 2006 7:53 am
Matt,
Rick White's righting pole uses rivets or screws to attach a bracket to the center of the beam. Seems a little overkill to through bolt it. The beams look alot bigger than H16's. Have you seen any problems with mounting these poles (start of cracks etc) I weigh 155 and have wings on the boat. Water bag just doesn't cut it.
cron
