It is currently Sat Dec 16, 2017 9:43 am
PostPosted: Fri Jul 08, 2005 4:23 am
Anybody come up with a slick cupholders for Getaways? That's something Hobie should design into the Getaway. Any suggestions?
Bob.
PostPosted: Fri Jul 08, 2005 1:08 pm
My son and I use these rubber rings with carabeaners (sp?) on them they slip over the end of bottle and you hook them where ever. Seems to work well. ou can get them at sporting good stores and I've seen them at other stores as well.
 Post subject: Getaway Cup Holders
PostPosted: Sun Jul 10, 2005 5:37 am
I found some clamp on pole mount cup holders at Wal-Mart that work well and I fit them to the the wing braces. One on each side. Very durable and removable.
 Post subject: Cup Holders??
PostPosted: Mon Sep 12, 2005 1:16 pm
I use the thing at the end of my arm!!! Its called a hand. LOL.. Had to do it! I just tuck it under the hiking straps or back into the cooler. If the air is honking you won't have the time to drink anything anyhow. Too much fun to be had. There are hundreds of options out there. Go to a bike store and buy a bottle holder for a bike and drill and tap into whatever you want. Use your imagination.... Good Luck!
PostPosted: Tue Sep 13, 2005 12:08 pm
On my old H16 I used some suction cup holders. They had a large suction cup on teh bottom and would fit nicly around a beer/soda can and go about halfway up the can. I would attache them to my paddle I had woven through teh tramp lacing. If you have a smooth part on your hulls they would hold there. I would also make a bottle noose and hang them from the boom. Since you don't have a boom that would be difficult.
I would avoid drilling and tapping into the boat. Just asking for one more place for corrosion to spring up.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Sun Jul 24, 2016 8:17 am
11 years later I have the same question. Am searching for a set up cup holders for the Getaway and will probably end up engineering my own from a modified bicycle bottle holder. (I plan on using tall cups... like a 20 or 30 ounce Yeti Growler.)
Before I get started does anyone have prior ideas to share?
Thanks!
PostPosted: Mon Jul 25, 2016 8:54 am
I've been thinking of getting two of these for my T2. Anyone try them?
https://www.westcoastsailing.net/default/bottleport.html
2014 T2
past: 1974 H14
PostPosted: Sat Jul 30, 2016 7:24 pm
So I ended up installing a pair of cup holders I found on Amazon.
Here's a picture of the "installation"
https://www.dropbox.com/s/2dvkq3wcc8whu ... 1.jpg?dl=0
They attach to the wing posts via velcro. I was concerned that this wouldn't be strong enough, but the velcro holds these in place without any movement around or down the post.
Here's a link to the ones I bought:
http://amzn.to/2ap6m96
They were $15 for a pair. I'll probably buy a second pair to keep in my boat box for when we have guests.
--Matt
PS: I'll update this thread in a few months with a report on how well these have held up.
PostPosted: Sun Jul 31, 2016 6:11 pm
Go to ebay and look for "Ronstan Drink Holder"...they attach with velcro. I'd attach them to the side of the wing seats where they will be handy. The glue will eventually stop holding, but then just remove and apply new velcro tape.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Mon Aug 01, 2016 2:03 pm
How about this?
https://www.amazon.com/Drinker-Beer-Sod ... B006CUJXMI
PostPosted: Sun Aug 07, 2016 5:03 pm
Ram level cup at Bass Pro...mount to wing seat strut.
PostPosted: Sun Aug 07, 2016 8:27 pm
http://bikase.com/
I've found that a lot of stuff for bicycles can be modified to work with boats--at least my boats.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Mon Aug 22, 2016 7:08 pm
None of the store bought cup holders have stood up to the abuse of people getting in out of the boat, slipping on, rubbing against etc. So we made our own.... They have lasted years now. I bought a 1.25" schedule 40 pvc and a 4" schedule 40 pvc, then painted both jet black to match the getaway wing seat hardware. Cut the 1.25" pipe into 4 pieces, 1 for each corner of the wing seats. Basically, the 4" pvc is where your beverage will sit. Use stainless steel bolts to attach the 4" pvc to the 1.25" pvc then use heavy duty zip ties to secure the 1.25"pvc to the wing seat uprights. This way you won't have to worry about drilling into the getaway. (Hint: the 1.25" pvc also serves as a fishing rod holder... We've caught spanish maceral with these while trolling.). See pics below.
ClamCounter
Hobie Getaway 2012
300 Mile Everglades Challenge '12, '13, '14, '15, '16, '17
PostPosted: Mon Aug 22, 2016 7:30 pm
Great job! Custom beats production 9 times out of 10.
R/Thom
SeaRail 19
Triak
BMW C600
