It is currently Wed Mar 29, 2017 10:54 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: moving a getaway
PostPosted: Mon Apr 03, 2006 6:40 am
I'll be able to the getaway on the beach rigged. If I'm solo, can i move the boat from the water up the sand to it resting place? slight incline....just want to make sure i can move it by my self...do i need a dolly or will some fenders under the hulls work? I know i could probably do the wave...thanks..this is a big consideration in my purchase
PostPosted: Mon Apr 03, 2006 8:12 am
Seeing as the H18 and Getaway are both in the same weight range (heavy) I will tell you that I have trouble pulling the H18 around on the sand. Lots of trouble. Plu it tears up the bottoms of the hulls. I would reccommend a dolly either hommade or production.
A winch on a post stuck into the ground will work as well.
Just so you know, I am 6'2" and 260lbs (a little winter weight has found me).
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Homemade Wheels
PostPosted: Mon Apr 03, 2006 10:02 am
PHLocker:
Make you some of these and save your back. Good luck with the Getaway.
http://dgaleana2.proboards56.com/index. ... 1143785090
I am getting a Mystere 4.3 for me and grand daughter to learn spinnaker on.
Doug Snell
www.tcdyc.com
PostPosted: Wed Apr 05, 2006 6:23 am
Moving a getaway up a beach, even on wheels is a challenge by yourself. That being said I would do it anyway, I am always able to find someone at the beach to help! Without wheels it would be very difficult at best. This is a great boat and very versatile wether your out alone or with your family of 5 or 6 or . . .
PostPosted: Fri Apr 07, 2006 10:58 am
thanks, this is a private beach, so sometimes unless the wife is around its just me
PostPosted: Mon Apr 17, 2006 9:29 am
I bit the bullet and bought a Seitech beach dolley with the fat wheels. Thanks to a buddy with a H17 sportcat I knew the Seitech would work. I did not like the price,but. after 3 years of use with my Getaway it has paid off. One disclaimer - you must be able to lift/lever the front half of your Getaway up about 2-3 ft to slip the dolley in and out, so start working on bench presses and overhead presses asap.
JJP(Tanglefoot3)
PostPosted: Mon Apr 17, 2006 9:39 am
the more i read, the more I am thinking the Getaway will be a pain in the A$$..Righting and hauling on the beach...
PostPosted: Mon Apr 17, 2006 10:01 am
so, how do you do that by yourself???
PostPosted: Mon Apr 17, 2006 10:11 am
Phil,
I put he dolley on while my boat is still in the water. All I do is tep on teh axel to get it under the hulls (it like to float). Then I roll it to where I want it. No bench press required here.
I wouldn't worry about it. You will be able to move the boat up the beach. And, if you find it too much work, think of a mechanical solution. Don't let all of this deter you from a great boat.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Apr 17, 2006 10:29 am
thanks, i was thinking that floating the boat and sliding the dolly under would be fine...thanks all
PostPosted: Tue Apr 18, 2006 6:21 am
what are the pros/cons on the seitech vs cat trax
PostPosted: Tue Apr 18, 2006 9:06 am
I ended up buying the cat trax just because that is what my local dealer had. I didn't want to pay for the shipping. If I remember the seitech can be broken down and fit into a trunk. Cat Trax cannot. I also think the seitech has spoked hubs the Cat Trax does not.
The Cat Trax bearings are cheap, simple, and robust. I can easily replace them if I need to for very little money.
Overall they are pretty much the same thing. I would base your purchase on price unless there is a feature that you must have on one or the other. If you are really inclined you can build your own. I know Doug on this site has been talking about the home built version quite a bit.
I don't know if I really answered your question but that was my 2 cents.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Tue Apr 18, 2006 9:32 am
the seitech looks nice as it has the handle which might make it easier to pull it up the beach....
PostPosted: Wed Apr 19, 2006 9:52 am
You can get a handle for the cat trax as well. Make sure you compare apples to apples and go for the best price. Remember to look at shipping as this can be a deciding factor.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: CatTrax
PostPosted: Wed Apr 19, 2006 10:09 am
Guys:
Most everyone I know here in Texas and La, uses. CatTrax. I have used them and the beach and on uneven ground at the lakes. They go over everything! I have had no trouble on a 340 lbs boat. Can move it with one hand.
Doug Snell
Hobie 17
Sunfish
Soon to be Mystere 4.3
www.tcdyc.com
