It is currently Sat Dec 16, 2017 9:30 am
 Post subject: Anchoring
PostPosted: Mon Jul 11, 2011 7:01 am
I’m new to the Getaway and have run into something I just can’t figure out. With all the mono-hull sailboats I’ve owned in the past, when you are at anchor with the mainsail up but free to swing (main sheet all the way out) would point directly into the wind and move very little. With the Getaway it wants to wander all over the place, even traveling upwind to the point of passing the anchor. I have tried all sorts of things with the rudder i.e. tied amidships, tied all the way to one side, fully up out of the water, etc. and cannot get the boat to sit still. The anchor is tied to the center of the forward crossbeam and the main sheet is disconnected from the sail. I've also tried close-hauling the main sail. I don’t want to have to take the sail down every time I want to stop for a swim, and would like to be able to anchor on a sand bar without my boat running into boats anchored nearby. What’s the secret to anchoring the Getaway?
Dave
 Post subject: Re: Anchoring
PostPosted: Mon Jul 11, 2011 8:54 am
I'd like to know as well. I've experienced the same problem.
2002 Getaway
"Cheshire Cat"
Used parts for sale. All original from 2002 Getaway. All showing their age but functional. Just pay shipping.
- Main and jib ---- SOLD.
- Main trampoline
- Wing seat covers
- shrouds
PostPosted: Mon Jul 11, 2011 11:46 am
2 anchors maybe? one off the bow and one off the stern?
Although it would certainly be a pain to carry two anchors on board...
PostPosted: Mon Jul 11, 2011 4:23 pm
Catamarans and Trimarans behave best with a bridle system for the anchor. Works well and keeps the boat from wandering all over. Each bridle arm should be about 8' to 10' for the Getaway.
PostPosted: Tue Jul 12, 2011 6:22 am
Also try releasing the downhaul. That will take some of the "bag" out of the sail.
But its like drgatsea said - the bridle system will help. I think all cats always wander like that.
If you are just going for a short swim, I wouldn't worry about it. if its a longer break, its pretty easy to drop the main. The boat will still wander, but just not as much and with a lot less force than when the main is up and catches the wind.
or just do like I do, swim when you tip over.
PostPosted: Thu Jul 14, 2011 7:36 pm
My 18 does the same thing. I once rigged up a dual anchor system. The anchors were about 30 feet apart and the boat was about 30 feet downwind. It worked better than a single even with the main up as long as lines were relatively tight.
Sail # 10505 or 277
Image Image
PostPosted: Thu Jul 14, 2011 8:02 pm
Hmm. Wondered about this too. Bridling is a good idea. Here's an interesting link: EZ Lay
PostPosted: Sat Jul 16, 2011 3:43 pm
Thanks drgatsea for the idea. I made up a 10' bridle and will try it on Sunday. What do you recomend for the mainsail and rudder? Should I leave the main loose or close-hauled? Tie the rudder amidships, to one side, or out of the water?
Dave
PostPosted: Tue Jul 19, 2011 6:22 pm
Hi Wxup - Most of the time I pull my Getaway up on the beach, facing the wind, rudders up, sail loose and it never goes anywhere. When we rent larger cats in the BVI's, we use a bridle, rudders are down, sails are usually down and again the boat stays put. I also have a Corsair F-24 (trimaran) and before I started using a bridle, the boat would sail past it's anchor all the time, unnerving if you plan on going to sleep. I now anchor with a bridle, boards up, rudder up and sails usually down and I don't have any problems.
If I was going to anchor the Getaway for a short stay, I would be comfortable with a bridle, rudders up, jib furled, mainsail up, slack in the sheets and uncleated. I'm not sure I would disconnect the main sheet from the sail either. Too easy for some one to get popped if the wind picks up. I also wouldn't wander far off. Stuff happens on the water, count on it.
But if you have sand, put the boat there. It's safest, easiest and the boat is made for it, you can't hurt it. Have fun!
PostPosted: Mon Jul 25, 2011 7:42 am
Hello guys this is what i learned about Anchoring your bout when nearing an anchorage, shorten up the painter if you are towing a dinghy, so it cannot possibly reach the propeller when backing the vessel.
Make sure crew members know what is expected of them. Remember, it is almost impossible to hear commands from the bow in the cockpit, so a few simple hand signals should be established.
Once in the bay, consider how the boats already there are anchored. Most will be swinging on a single anchor warp. But in heavy weather, some may be using an anchor weight, some may have two anchors set off the bow, or one off the bow and one set astern. Some may be on permanent moorings. When the wind or current shifts, the vessel with an anchor weight or two bow anchors set, will swing in a shorter radius than boats on a single anchor. Vessels anchored fore and aft won’t swing at all. Those on permanent moorings will pivot around their bows, but move very little. In very light air, boats with all chain anchoring systems may not swing as far or as quickly as those riding a mostly nylon warp.
As the newest arrival, you must anchor to keep clear of boats already at anchor. Make sure you allow for any change in wind direction and strength. It is always safer to leave extra space around your boat.
Position your boat with the bow to the wind (or the current, if that is stronger), roughly equidistant from your nearest neighbors in the approximate location you wish to be in when anchored. Make sure you will have ample water beneath you at dead low tide.
How To Kiss
