It is currently Sat Nov 18, 2017 9:52 am
 Post subject: Mast rotation
PostPosted: Fri Aug 04, 2006 6:13 am
Something like this may help. Pulls it forward when off the wind and when you sheet in it should rotate back. There is a line on each side that doesn't show in the pic. There is a piece of shock cord with loops at each end that runs up to a piece of line that run between the bows. I will try to take some better pics next weekend. Forget about the boom setup as you don't have a boom right?
Hope this helps.
http://www.thebeachcats.com/modules.php?set_albumName=Doug-and-Ashleigh-Snell&id=cd1260_R1_20&op=modload&name=gallery&file=index&include=view_photo.php
Doug
PostPosted: Tue Aug 15, 2006 6:41 am
still having an issue...when i pull the line the drum UNravels rather than furling the sail....i have to do it by hand....frustration!!!!!!!
PostPosted: Tue Sep 05, 2006 6:04 am
still having an issue, when i pull the line to roll in the sail it actullay unfurls the sail......help!! if i am on the tramp looking forward, which way should i be hand winding it to correct this issue???
PostPosted: Tue Sep 05, 2006 7:00 am
After your rig is up and before you connect the Jib sheets. Pull all the cord from the drum, then wind looking down turn the jib 3 or 4 rotations clockwise to pre wind it. (If you don't it will not furl completely.) Cleat the furling cord and connect the sheets trying not to lose too much of the prewind. Pull and cleat the sheets to tighten it all up till needed.
PostPosted: Mon Sep 18, 2006 5:24 am
NO LUCK!!! I tried yesterday to fix the issue....when i am on the front tramp looking down at the drum, i have to manually wind it from right to left (counter clock wise) to have the sail furl so the clip is on the outside. I know that when the sail is wound up, there should be no line in the drum and when the sail is in the "sailing" position, the drum is full of line...i think i have to disconnect the rig and start over...also where do you all connect the line from the front grommet of the jib to the forestay???
