It is currently Mon Jan 22, 2018 6:03 pm
PostPosted: Fri May 16, 2014 8:15 am
Did Hobie make 2 different sizes to fit on top of the Getaway traveler where you pin the main sheet to the traveler car using clevis pins and our favorite ring dings? Mine is 3/16 and is a pain to connect. Bought a really trick 1/4 inch quick pin by mistake and I want to use that instead of what I got. Is that an item that can be purchased and installed = the 1/4 inch U shaped stainless steel bracket that sits on top of the Getaway traveler tracker car? Part Number? Cost? Thanks !!!
PostPosted: Fri May 16, 2014 8:37 am
Online
The deck plate is only available in 3/16". Same as used for 14,16,17... short span 3/16" pin, plenty strong.
