It is currently Sat Jan 20, 2018 4:44 pm
 Post subject: Comp Tips
PostPosted: Wed Dec 13, 2006 7:34 pm
In reading various posts the term "comp tip" has appeared several times. Could someone explain the history of these and what benefit they provide over a single mast? Do they have a useful life shorter than the aluminum masts? What problems are seen with them? I'm looking forward to many years of sailing my Getaway and I the more I know about the boat the better.
Thanks,
Barry Martin
 Post subject: CompTips
PostPosted: Thu Dec 14, 2006 10:08 am
Every Hobie Cat built in the USA since the mid 80's has had a CompTip upper mast. This is a safety feature to hel;p prevent electrocution if the mast contacts a high power line during sailing, rigging or moving the boat.
From the FAQ section of the forums:
A CompTip is the upper section of Hobie masts built starting in / after 1986 (Hobie started with Hobie 16's and later all models). They are fiberglass and non-conductive. They were designed to prevent electrocution by contact with a high power line. Thousands of older Hobie Cats were retrofitted with the CompTip.
PostPosted: Thu Dec 14, 2006 1:45 pm
There should be no difference in useful life if the Comptip is maintained properly. It should be protected from the sun when the boat is not being used. It's plastic and fiberglass and will crack and / or shatter if it's dropped repeatedly (aluminum will bend, so there's really no difference there).
It needs a little more care than an all-aluminum mast, but it's worth having the safety factor.
PostPosted: Thu Dec 14, 2006 6:40 pm
Thanks for the school session. I have a lot to learn about these boats so I really appreciate the information.
Barry Martin
