Hobie Getaway transom bolts stripped - how to repair? http://www.hobie.com/forums/viewtopic.php?f=23&t=70477 |
Author: | jlaurento [ Mon Dec 19, 2022 4:52 pm ] |
Post subject: | Hobie Getaway transom bolts stripped - how to repair? |
The female threads on the rear transom that the bolt goes into that holds the pintel is stripped. I'm not sure how to repair it. Does anyone have a fix. The bolt goes in but just spins. |
Author: | hobie_sls [ Wed Dec 21, 2022 9:45 am ] |
Post subject: | Re: Hobie Getaway transom bolts stripped - how to repair? |
Unfortunately there is no repair for the insert. It is one piece and inter connected. You might try stepping up a screw size? If that doesn't work you could through bolt, but this would require a port installed in the aft deck to access the inside of the transom. |
Author: | nu2sail [ Wed Dec 21, 2022 12:50 pm ] |
How about tapping the screw hole to allow a bigger screw. I have done this a few times to great success. |
Author: | Steve C [ Wed Dec 21, 2022 3:26 pm ] |
I think JB Weld & Loctite have a product that can repair threads, never tried it. I have used helicoils & inserts for different things in the past. |
