It is currently Wed Apr 24, 2024 11:46 am
 Post subject: Bridle Eyestrap Anchor
PostPosted: Sat Apr 21, 2018 4:04 pm
While replacing a bridle eyestrap, the bolt has been epoxy set into the anchor, and I ended up breaking the bolt in the anchor.
While trying to drill out the bolt, the bit snapped. It is taking forever to drill out and try to re-tap.
Is there an easier way?
PostPosted: Tue Jul 03, 2018 9:09 pm
[url]https://photos.app.goo.gl/yY4uJPYXGS9aXas99
[/url]
PostPosted: Fri Jul 06, 2018 10:06 am
That would require something different to fix.
Maybe bolts through the hull from side to side below the insert to mounts a bale or strap to hang the bridle on.
This is the idea, but since one bolt is sheared. Mount a strap up a bit to hook the bridle direct.
