It is currently Tue Dec 12, 2017 7:29 am
PostPosted: Mon Oct 25, 2010 2:52 pm
Can I get an (Anti Pitch Pole Hydro Foil) for a Hobie Wave? If so what is the cost?
PostPosted: Mon Oct 25, 2010 4:13 pm
There is not an anti pitchpole foil designed for anything but the Hobie 16 (can fit a 14) that I have seen.
PostPosted: Mon Oct 25, 2010 5:05 pm
Hobie should make one for the Wave.
PostPosted: Mon Oct 25, 2010 5:59 pm
The anti-pitchpole device is called a mainsheet.
Of course you need to place yourself properly on the boat, but you simply need to lift the throttle.
Jack Woehrle
Wave #100
H20 #287 "Tallahassee Lassie" (down in FLA)
PostPosted: Mon Oct 25, 2010 8:51 pm
Wave is fairly easy to put the bow down under water in a trough. I would like something like in the Hobie Parts & Accessories 2010-11 part #30110 for a Wave. I want to keep up my speed & not flip the boat.
PostPosted: Tue Oct 26, 2010 8:58 am
I think I am just heavy enough (190ish lbs) to keep that little bastard from pitching all the way over. I have buried the hulls past the crossbar a million times and have not gone over, but I have done that whole spin thing when the rudders come out of the water and the boat rotates 90 degrees and hits the water. That's kinda fun (unless you're racing) but the boat won't go over frontways or sideways with me hiked out. Just too fat I guess.
PostPosted: Tue Oct 26, 2010 9:41 am
The traveler kit also helps. Travel down a bit to keep the boat more level. Not class legal for racing, but works well.
PostPosted: Tue Oct 26, 2010 9:51 am
You wont want a anti pich hydro foil on the bow of a wave. As soon as that foil goes underwater its just going to dig the bow into the water more. At that point you are going to pitchpole. Aside from getting T-foil rudders, the only real way to stop it is as described above... Sheet out, and get your weight back.
Personally I think pitching on the wave is a blast and I look forward to it.
1992 Hobie Cat 18 #16943
PostPosted: Tue Oct 26, 2010 10:08 am
We'll see how much you like it when you eating my (censored) down in Mississippi next year.
PostPosted: Tue Oct 26, 2010 12:14 pm
What is a traveler kit? What is the catalog # for it & what is the cost?
PostPosted: Tue Oct 26, 2010 12:23 pm
The kit adds a track on the rear beam and a traveler car with control cleat. This system is like the H14 or H16 main traveler.
# 39250000 MAIN TRAVELER KIT - CLUB WAVE ($229.00 USD / Oct 2010)
Does not work on a Classic (SE) Wave with the aft tramp straps.
PostPosted: Thu Oct 28, 2010 7:16 pm
I put a traveler on my SE just had to do somemodifications. Results the tramp is tighter, I don't take it apart anyway. There has been pictures of others that have also fixed up their SE you would have to look it up in past blogs
