It is currently Fri Jan 19, 2018 9:21 am
PostPosted: Sun Jun 19, 2011 7:13 pm
How much water do you get in your hulls on a typical sailing day?
Did you ever determine how it was getting in?
How did you remedy the problem?
PostPosted: Mon Jun 20, 2011 7:59 am
I just purchased a new 2011 wave standard (not club). Made sure that no water was in the hulls before taking it out the first time. I've taken it out to the ocean a few times and on the river and I haven't seen any appreciable water buildup. < 1 cup / hull after 5 outings.
PostPosted: Mon Jun 20, 2011 12:50 pm
I'm convinced that most water comes in from topside. My boats run dry unless it's raining and then they make take on a half gallon of water in several hours time.
Anywhere you have a hatch or a screw or fitting penetrates the hull is a likely water entry spot.
PostPosted: Mon Jun 20, 2011 1:39 pm
Check the seat areas. Loose seat pads and a failed seal on the cover plate underneath seem to be the primary cause of hull leaks.
Do a soapy water test to confirm any leak location:
http://www.hobiecat.com/forums/viewtopic.php?f=18&t=169
