Survey Questions - water in hulls http://www.hobie.com/forums/viewtopic.php?f=24&t=36290 |
Author: | zojoe [ Sun Jun 19, 2011 7:13 pm ] |
Post subject: | Survey Questions - water in hulls |
How much water do you get in your hulls on a typical sailing day? Did you ever determine how it was getting in? How did you remedy the problem? |
Author: | RogerYoung [ Mon Jun 20, 2011 7:59 am ] |
Post subject: | Re: Survey Questions - water in hulls |
I just purchased a new 2011 wave standard (not club). Made sure that no water was in the hulls before taking it out the first time. I've taken it out to the ocean a few times and on the river and I haven't seen any appreciable water buildup. < 1 cup / hull after 5 outings. |
Author: | Tom Kirkman [ Mon Jun 20, 2011 12:50 pm ] |
I'm convinced that most water comes in from topside. My boats run dry unless it's raining and then they make take on a half gallon of water in several hours time. Anywhere you have a hatch or a screw or fitting penetrates the hull is a likely water entry spot. |
Author: | mmiller [ Mon Jun 20, 2011 1:39 pm ] |
Check the seat areas. Loose seat pads and a failed seal on the cover plate underneath seem to be the primary cause of hull leaks. Do a soapy water test to confirm any leak location: http://www.hobiecat.com/forums/viewtopic.php?f=18&t=169 |
