It is currently Sat Jan 20, 2018 12:54 pm
PostPosted: Sat Jul 02, 2011 11:48 am
I've searched around here and couldn't find any mention of whether the Wave has a metal backing plate built into the sterns for the gudgeon screws. Need some help from rotomold boat experts.
This came up in the Technical Help forum at TheBeachcats.com with a member who has two broken gudgeon screws it looks like need to be drilled out, enlarging the hole.
If there is no metal plate, could the holes be enlarged, filled in with epoxy, then re-drilled to the correct size?
Thread with pictures of damage.
http://www.thebeachcats.com/forums/viewtopic/topic/12647
Thanks,
Damon Linkous
1992 Hobie 18
www.MemphisGuru.com
www.Catsailor.com
www.TheBeachcats.com
PostPosted: Tue Jul 05, 2011 7:37 pm
mmiller wrote:
Yes, there are molded-in inserts.
May be aluminum or stainless on this year vintage (1998). Newer boats use bronze.
Will require careful drilling to limit heat and a screw extractor.
From the topic New owner need help
1992 Hobie Cat 18 #16943
PostPosted: Tue Jul 05, 2011 8:13 pm
Sorry, really did look and didn't find that topic before I posted. Moderator please delete or merge this topic with the other one.
Damon Linkous
1992 Hobie 18
www.MemphisGuru.com
www.Catsailor.com
PostPosted: Wed Jul 06, 2011 7:21 am
Its cool, I just wanted to point you in the right direction.
