It is currently Wed Jun 28, 2017 3:02 pm
 Post subject: Halyard question
PostPosted: Sun Aug 14, 2011 7:32 pm
I am still new to this... just set a used wave up in the front yard. Is the halyard the rope with a brass fitting and braided wire and a loop? My braided wire is completely rusted through and broken. New halyard $78? No way to rebuild or reuse some of the parts?
 Post subject: Re: Halyard question
PostPosted: Mon Aug 15, 2011 4:45 am
The wire section is the most critical part. It holds all the tension of the sail. The brass bead is the next most important part, and it's not reusable either.
$78 does seem a bit excessive. You can use an H16 halyard, the rope section will just be too long.
It pays to shop around, but remember genuine Hobie parts are the best.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
PostPosted: Mon Aug 15, 2011 4:52 am
I think that a new halyard is worth the money, unless your marlinspike seamanship skills are something you would bet a long paddle on, but would still buy all new lines and whatever else you may need to duplicate a new one.
Also marine gear is always going to seem a bit expensive, but it something that you really have to depend on, and 78$ sounds worth it.
8)
PostPosted: Mon Aug 15, 2011 10:16 am
Wow - rusted? I wonder if it was not a Hobie Halyard.
PostPosted: Mon Aug 22, 2011 5:00 pm
The wire portion will be too long as well. The Wave mast head is smaller.
This type of halyard is a pain to build, so cost is up there.
I doubt rust was the cause of failure. Rust gathers on the surface of the wires in the bundle due to dirt and salt, but typically would not rust through. The failures happen at the hook point and is exacerbated by bending at the joint each hoist.
PostPosted: Sun Sep 04, 2011 7:50 pm
https://picasaweb.google.com/1032212279 ... /HobieWave
