It is currently Thu Apr 25, 2024 6:30 am
PostPosted: Fri Jan 06, 2012 6:42 pm
Take the end of the main sheet and pass it from forward through the swivel jaws, dead eye then through the car and finally the eye behind the track...
This doesn't seem to make sense... the end of the main sheet is what ya pull on to sheet in and out.. so if I do as stated this end will be tied off at the behind the track...?
I thought you used a separate line to control the traveler, but this makes no mention of that, or of cutting a section of the main off to use for this.. I figure thats what I need to do but want to make sure.
Over all the install from start to finish took me an hour and a half, 1/3 of that being drilling out the original eye screws. Not too bad at all really.
PostPosted: Fri Jan 06, 2012 7:22 pm
Never mind, found a picture. 8)
Done! :mrgreen:
