It is currently Wed Jan 23, 2019 10:15 pm
PostPosted: Sat Mar 28, 2015 6:41 pm
I've seen a lot of posts from guys complaining that they can't get the trampoline on their "classic" Wave tight enough. Well, here's one solution to the problem. I just installed a new tramp I got from Slo Sail and Canvas.
They have a tramp on their website for the "classic" Wave that has rear lacing. This is a good start, and it allows for the installation of a main sheet traveler as well, because it eliminates the velcro straps around the rear crossbar.
I called them though to see if we could take things one step further. I asked them if they would add lacing down the middle for me. They said, "sure, no problem". Here's some pics of the finished product.
Jim
PostPosted: Sun Mar 29, 2015 4:37 am
Man that looks nice, AND TIGHT !!!!!!!!!!!!!!!!!!!
Way to go Dude !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Sun Mar 29, 2015 9:25 am
That does look sharp. My only concern would be how much load can those stainless steel hooks for the tramp wires take? Specifically, how are the hooks fastened to the hull? Is there a threaded insert in the hull, or is it just a self-tapping screw that's screwed into the plastic? If it's a self-tapping screw, I think you just want to be careful not to rip it out of the plastic with too much tension. Otherwise, I think it looks real nice - nothing worse than a saggy tramp.
PostPosted: Sun Mar 29, 2015 10:03 am
Those hooks screw into a threaded aluminum insert that's embedded into the hull. It is standard pre 2001 (I think that's when they switched over to all Waves having the tracks) Hobie stock. It should be just as strong as the tracks are.
This is a 1998 "classic" Wave.
I think it looks good too. Thanks.
Slo might be getting more orders.......
Jim
PostPosted: Sun Mar 29, 2015 12:44 pm
Wow. Those look great. Coincidentally, I just ordered aft tramps for my Getaway yesterday. I got the same color and added the zipper pocket as well.
I already had an SLO forward tramp, but the mesh is so fine it acted like a sail and caught the wind when flying a hull or trying to right the boat. Other than Hobie, is there somewhere I could get a forward tramp with mesh similar to the stock one?
2011 Hobie Mirage Adventure
Caribbean Blue
ST Turbo Fins, Sail Kit (w/home-made furler), Sailing Rudder, SideKick Ama Kit, Daggerboard, iComfort Seat Pad, GoPro Hero3+, RTIC SoftPak 30, Seattle Sports Scupper Swift Cart
PostPosted: Sun Mar 29, 2015 1:49 pm
Not sure who might have the same material as stock, but many companies will send you samples of the material they use.
Jim
PostPosted: Sat Apr 18, 2015 6:27 am
I am trying a little different approach to getting my tramp tight. I take ratchet tie down straps and hook them up underneath the tramp. from bow to stern and from port to starboard. four straps. Not only is the tarp tighter I have a better place to step on when I get on the boat. I started this because my toe holds were starting to tear . So I now have new toe holds by the use of a ratchet tie down strap. Don't over tighten for fear of pulling out brackets on tramp cables. I have a old 1997 Se
catch me if you can clark
PostPosted: Sat Apr 18, 2015 6:50 pm
To the OP, How much extra did they charge you for the center lacing?
PostPosted: Sun Apr 19, 2015 9:22 am
You'll have to give them a call for pricing. I don't want to tell you something wrong.
(805)479-6122
Jim
PostPosted: Tue Apr 21, 2015 12:46 pm
The product has been officially added to the SLOSC website for anyone that's interested.
Tom
Tom
Fleet 259, Central Coast CA
H18 ('81)
H18 ('85)
H20 ('97)
H18 ('78)
PostPosted: Wed Apr 06, 2016 9:25 pm
Hi, are those new seat pads from hobie?
PostPosted: Thu Apr 07, 2016 8:31 am
I got the seat pads from hydroturf.com
Jim
PostPosted: Thu Apr 07, 2016 10:08 am
What are you using on the side that hooks into the metal hooks? It looks to be line not wire. Always have trouble getting the wire to stop fraying.
Thanks,
Ty
PostPosted: Thu Apr 07, 2016 12:06 pm
I do have the cables on there, but I put a cover on the cables to help stop the fraying.
http://www.murrays.com/53-100.html
Jim
PostPosted: Fri Aug 17, 2018 7:43 am
I know this is an old thread, however I am wondering how that tramp has worked out over the past few years?
