It is currently Fri Oct 18, 2019 12:38 pm
 Post subject: Wave Bridle 99060510
PostPosted: Tue Sep 08, 2015 5:50 am
I am on a sailing holiday in Spain and someone has 'borrowed' the wire set which was attached to the hulls. :x I have ordered replacements but they will take some time to get here.
A local sailmaker can fix me up with temporary replacements so that I can continue to sail - including new Bridles - but he needs to know the length.
Can anybody tell me the length of a Wave Bridle 99060510? I cannot find it on the internet.
I think it is about 1.50 metres but I need to fairly accurately as the stay adjuster is quite short.
I hope someone can assist.
 Post subject: Re: Wave Bridle 99060510
PostPosted: Tue Sep 08, 2015 6:44 am
My bridle wires are 5' long. That's 152.4 cm.
This is a Pull-to-Pull Measurement - I measure the wire by putting a screwdriver blade in each thimble, and pull the wire tight. Then measure to the OUTSIDE of each screw driver blade.
Jim
PostPosted: Sat Sep 12, 2015 10:13 am
Thank you Jim - they have cut the bridles to that length in 4mm braided wire and they fit perfectly. Can now go sailing :D
