It is currently Fri May 29, 2020 2:34 am
PostPosted: Sat Apr 13, 2019 8:08 am
I’m looking to buy a used Wave without a trailer. I have access to a 16 trailer and am not sure if the Wave will fit.
The 16 trailer has a homemade sail box that is 50” wide and 19” tall from the frame. Would the Wave fit over the box? I found a post that said it is 55” between the hulls so I assume the width is ok. I’m not sure what the Wave height is under the trampoline.
I also found a post that said the roller spacing on the trailer should be 69” wide for a Wave. Does that sound correct?
Thanks.
PostPosted: Sun Apr 14, 2019 7:37 am
The 55 inch between the hulls and the 69 inch center to center on the rollers is accurate but my boat only sits 18 inches from the bottom of the hulls to the trampoline. If your boat sits up another two inches for the rollers you might be okay. My trailer has a center beam that is as high as the rollers so I only have 18 inches of clearance under mine.
2012 Hobie Wave "Latitude"
Shell Point Florida
PostPosted: Sun Apr 14, 2019 8:04 am
Thanks for checking.
