It is currently Wed Apr 24, 2024 8:43 am
 Post subject: Drain Plug Size???
PostPosted: Mon Jul 12, 2021 6:46 pm
Do the old ('97) Wave Classic/SE use a different drain plug? The ones I just received are ~3/4 inch in diameter and the hole in the hull is around 1/4" or 3/8". Did I receive the wrong parts or do I need a different part number? 10091000 is what I think I have.
 Post subject: Re: Drain Plug Size???
PostPosted: Tue Jul 13, 2021 10:02 am
Original was 3/8"
https://www.hobie.com/parts-and-accessories/?ItemGroup%5Bquery%5D=91281000
PostPosted: Mon Jan 17, 2022 2:14 pm
Matt - I am thinking about changing the drain plug to the current style so it is easier to take out and put back in. Would you put the new drain plug next to existing one or use a hole saw and drill around the existing drain port? Is there a backing or something that would not be easy to drill through? Thanks in advance
