It is currently Fri Jul 21, 2017 2:19 pm
 Post subject: Rudder alignment
PostPosted: Wed Jul 11, 2007 12:49 pm
I'm pretty sure that the Wave's rudders are supposed to be "toe-in" (which I think of as "pigeon-toed"), but I wonder if mine are correct:
When one is set to be in-line with the hull
The other one is turned in at a pretty dramatic angle
Is this correct? If not, what can I do about it?
Also, I seem to have a lot of fore and aft play in the rudder, even with the rudder arm bracket set at maximum tight (all the way forward)
Enjoying the boat, regardless,
Kevin
PostPosted: Wed Jul 11, 2007 1:00 pm
There is a left and a right rudder - you have them reversed :)
As for the fore-aft movement, sounds like the cams aren't locking right - with the cam plate all the way forward, there shouldn't be much if any play at all.
Tim
Unofficial Fleet 72 Communications Officer and Div 4 Webmaster
http://www.hobiefleet72.org
http://www.div4.hobieclass.com/
PostPosted: Wed Jul 11, 2007 1:09 pm
Tim:
Thanks for the reply. But, inside the rudder housing on the port hull, there's a letter "L"; inside the housing on the starboard hull, there's a letter "R."
Are you sure that's backwards?
Kevin
 Post subject: Left to Right?
PostPosted: Wed Jul 11, 2007 1:40 pm
Yep... backwards.
The L and R inside the older castings are mold makers marks and do not represent Left and Right on the boat. Sorry.
The tiller arms should bow towards the centerline of the boat.
Reversing the rudders will fix the isue you have.
PostPosted: Wed Jul 11, 2007 2:18 pm
If you regularly take the rudders off for trailering or storage, stencil an L and R, or P and S, or put some red and green tape on em so you don't have to spend time figuring it out every time you put the rudders back on!
Tim
 Post subject: Re: Left to Right?
PostPosted: Thu Jul 12, 2007 5:33 am
Boy, will I get some humor mileage out of that.
Thanks for the solution.
Kevin
Users browsing this forum: sharkdog99 and 2 guests
