kiteman36,
I have two 2008 models that have lever up/down rudder control and the twist knob mirage drive locks, so the 2007 will be the same. 2010 came with the new snap locks and pull rope up/down rudder control.
As for the price... whether or not it has been in the water IMO it sounds a bit overpriced for the year. Used Hobies hold their price well but for example I got the last 2008 model from my dealer for 1050.00 brand spankin new since he had a showroom full of 2010 models. Personally I would offer him less maybe 1100.00 (maybe he will meet you in the middle). You can see people asking 900.00 to 1300.00 on the web for a 2007 revolution.
Even if he says it has never been used be on the cautious side and look it over well for any cracks at mast brace/support inside hull and at the scupper holes. If possible do a leak test with the kayak on supports and fill with some water and look for drips. Make sure the mirage drive screw locks are not stripped or cracked. Minor scratches, blemishes and wear and tear are ok, just make sure no deep gouges. Inspect and test the rudder control lines. Inspect the Mirage drive for any chipped sprockets or excessive wear. Look for excessive rust or corrosion at the bare cable area near the bolts on the mirage drive. I have seen posts of cable failures there due to rust or corrosion on older drives). My 08's have had lots of fresh and saltwater use and are still fine.
Just adding my 2 cents.
Revo
_________________ I would rather be kayaking and think about work than to be at work thinking about kayaking.
