Tom Kirkman wrote:
I don't think it'll work in a shoot-thru-hull configuration.
What you may have to do is fabricate a mount that you can swing up while under strong sail power, and swing down when you're moving slower.
yes tom i have that at the moment but was keen to get some depth readings at speed to avoid running aground. that said i have one solution to try. A string from the bottom of the swing over arm forwards to keep it in place.
cheaper than a new transducer!
here is the revo setup
May the odds be ever in your favor..
