It is currently Thu Jan 18, 2018 7:29 pm
 Post subject: Leaks in the REVO
PostPosted: Sun Oct 28, 2007 1:52 pm
Went hoopin for Lobsters for the first time to weeks ago and developed a serious leak. I was pump out @ 1" of water every 30 min from inside the hull. The next day after skunkin out I brought the REVO back to XTREAMLINE Sports in San Pedro. Greg water tested it and found a double leak !!!
The plastic had cracked under the cams that lock in the mirage drive. Basically it started from the threads that hold the 3-4 in stainless steel bolts that hold the cams down.
Unfortunately most of Hobie's staff was off on work in Fiji, must be nice
:D
Needless to say Hobie sent a replacement REVO, it took 2 weeks, although the Hobie HQ is only like 60-90 minutes away. I think that my delivery was based on their delivery schedule to the Los Angeles area. I think it was totally appropriate.
Will be doing sea trials with some fishing monday morning. Thanks HOBIE and XTREAMLINE , you guys rock !!!!!!!
MikeG
Hobie Mirage Revolution
Ocean Kayak Prowler 13
- Look ma no hands
PostPosted: Wed Oct 31, 2007 11:33 pm
Mike,
Thanks good to know, Hope your new unit is ok..
I have an 07 hull fron Xstreamline on 10-10-07
I put 6 hr's on so far so good.. Is there a way to check without removing the bolts ?
John Rhodes
New Revo, ST's
Sailing Rudder. Thx Xstreamline.com
Hummingbird 220 FF.
REVO in LA Harbor
Harbor City,
Doesn't have a harbor...
Nor is it a City...
PostPosted: Fri Nov 02, 2007 10:31 am
Unfortunately not really
The black plastic cams covered it.
We actually had to do an inverted water test to find it
- Look ma no hands
Users browsing this forum: Google [Bot] and 6 guests
cron
