It is currently Fri Jun 23, 2017 12:02 pm
 Post subject: Hobie Livewell MOD
PostPosted: Mon May 12, 2008 6:08 pm
Sorry for the delay
heres pics plus somewhat detailed instructions
2 x (1/4" )female threaded pvc elbow with mips fitting
1 3" section tubing
Locate ring holding tsunami pump in place on underside
Remove ring
Remove pump from well and add elbow # 1 to threaded outlet (the tube thats normally inside the livewell)
Place back in livewell and re-connect ring
(no pic)
Take section of tubing and add 2nd pvc elbow
This 2nd elbow will become your new outlet
I choose this fitting cuz I had it
I believe a fitting is need here so water sdoesn't just spout up and you have a little control of how the water flows
Take tube and connect to mips fitting on pump (DONE !!!)
Adjust as necessary
Hope this helps
MikeG
Hobie Mirage Revolution
Ocean Kayak Prowler 13
- Look ma no hands
PostPosted: Mon May 12, 2008 9:04 pm
MG, great how-to with excellent illustrations. Thanks!! 8)
