It is currently Tue Jan 15, 2019 9:35 pm
PostPosted: Fri May 26, 2017 4:16 am
Hi fellow members,
Does anyone has experience to bungee the Hobie cart in the two factory holes and use all the way to fishing without taking it out until finish?
Thanks in advance!
PostPosted: Wed Jul 26, 2017 4:21 am
I guess it depends on which kayak you have. On my PA14, I insert the cart upside down through the rear handle and attach a bungee to the axle. I tension the bungee so that the cart sits high enough in the handle to keep it out of the water.
Most folks just put it in the rear scupper holes with no bungee at all. I'd recommend at least using a leash if you will be on rough water.
2014 PA14 me
2017 Outback wife
