It is currently Fri Feb 26, 2021 12:25 am
PostPosted: Mon May 06, 2019 6:46 am
I sold my PA12 a few years back and currently have 2 outbacks and a revolution 13. I am looking to add a PA14 or an AI. I am leaning toward the AI since I do not get to fish much with the whole family going out, but have a few questions. I live in Tulsa, OK. We have a lot of lakes around us. I typically go to smaller lakes (Shell lake would be the smallest), but also will go to the larger ones a few times a year (Keystone, Grand Lake O' the Cherokees, Tenkiller). Also, I will have one or two 4 year olds along with me from time to time. Right now I am waiting for the local kayak shop to get an AI so I can get a demo completed.
How big of a lake is needed to enjoy a AI?
If I do not use the sail on an outing how does pedaling an AI with AMA/AKA compare to the PA as fair as speed and resistance?
PostPosted: Mon May 06, 2019 11:28 pm
Hey Nate I was in much the same boat as you and was about to purchase a tandem island until I found out about the capacity plates. Just so you know the adventure island has a capacity of One and 400lbs and the Tandem Island has a capacity of 2 and 600lbs. It might be a good idea to check your state and see how Fish and Wildlife handle those plates. I am in Kentucky and was rather disappointed to find out I can't have more than one on the AI and two on the TI! The amma's and akka's and tramps add nothing to the stated capacity!
PostPosted: Tue May 07, 2019 5:12 am
I have found that even the local small lakes are enjoyable with my TI on those perfect breezy days and you just can't devote an entire day to drive the larger options further away.
My track one day last summer on Lake Pehlam Reservoir which is only 255 acres.
https://www.dgif.virginia.gov/waterbody ... reservoir/
PostPosted: Tue May 07, 2019 5:50 am
That is a good point and something I will look into. I currently have the kids either being towed in Dagger Zydeco's or sitting on the front of the outbacks and no one has bothered us. I would rather look into this now then find out at the lake I'm doing something I shouldn't be doing. Thanks for the heads up on this.
PostPosted: Tue May 07, 2019 6:02 am
This is very helpful. Thank you for linking the lake as well. I was able to compare this to the smallest lake I would be going to. I did not expect to be able to use the tail portion of Shell Lake, but it looks like that wouldn't be an issue at all.
https://www.sandspringsok.org/289/Shell-Lake
PostPosted: Tue May 07, 2019 3:56 pm
I’ve had both. Pedaling a dressed out AI is a bit easier than the PA.
