It is currently Sun Jun 25, 2017 3:42 pm
 Post subject: Jib sail
PostPosted: Sat Mar 22, 2008 6:33 am
Just saw this older post of your jib sail and thought I would share what I did on my jib. My jib looks almost identical to yours, except I mounted my amas in front instead of behind. This did two very good things; you can through-bolt the main support bar instead of using well nuts and second the side stays can be attached to the ends of the amas, at the float attachment. This gives a much wider triangle and much more mast support. This has really worked well for me.
 Post subject: Re: Jib sail
PostPosted: Fri Mar 28, 2008 7:15 pm
[quote="gregw"]Just saw this older post of your jib sail and thought I would share what I did on my jib. My jib looks almost identical to yours, except I mounted my amas in front instead of behind. This did two very good things; you can through-bolt the main support bar instead of using well nuts and second the side stays can be attached to the ends of the amas, at the float attachment. This gives a much wider triangle and much more mast support. This has really worked well for me.[/quote]
Take a look at KFS site and check that hydrovision fin attached to the amas..that would be great if you figured a way to get that going for a trial on AI ama.
PostPosted: Sat Mar 29, 2008 5:38 am
Take a look at KFS site and check that hydrovision fin attached to the amas..that would be great if you figured a way to get that going for a trial on AI ama.[/quote]
I can't find anything on the KFS forum about "hydrovision fins".
Please provide a link, Thanks.
PostPosted: Sat Mar 29, 2008 6:11 am
I guess it´s the foil to a Raptor 16 that is mentioned.
http://www.hydrovisions.com/
click on "How it works"
PostPosted: Thu Apr 17, 2008 6:56 pm
Hydrovision sailing out riggger... goggle that.... I still don't know how to add items. Sorry I did not reply sonner.
