It is currently Sat Jul 22, 2017 8:01 am
 Post subject: Rocky shore storage
PostPosted: Sun May 27, 2012 8:00 pm
We purchased a Hobie 20 for lake sailing in Canada. This is a beautiful catamaran that we plan to have at the cottage. We do not have a sand beach and are going to design a shore storage system. Should the hulls just be on craddle points in the 4 corners or can we support the length of the hulls. Also would it matter is the hulls are angled towards the water re mast weight? Thank you for any advice you may have! Gord
H 20 Miracle 808
 Post subject: Re: Rocky shore storage
PostPosted: Wed May 30, 2012 5:15 pm
Cradles at four points work. Under the cross members. Full length bunks would also work. The mast tipped aft is no problem. There is far greater load on the wires and fittings while sailing. We offer carpeted (trailer) cradles to fit these. Aft set tips, so you could mount on posts or a 4x4 beam structure at the waters edge. Slide the bows up on the aft set... and then pull forward.
These are no longer shown in the catalog, but listed in the back as aft and forward sets. 48030001 FWD $ 173.00 / 48040001 AFT $ 208.00
PostPosted: Wed May 30, 2012 9:32 pm
I made a post in the Hobie 16 section, complete with pictures, regarding the ramp that we use in Shreveport: viewtopic.php?f=14&t=42851. It works great, and depending on your shoreline characteristics, it could probably be adapted to your needs.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Thu May 31, 2012 7:24 pm
Just have to remember to lift your boards.... right? :wink:
PostPosted: Thu May 31, 2012 7:37 pm
It's hard to see on the picture, but I have a rocky beach and made some sliders, basically a ladder with ABS pipe rungs to slide on.
As the years go buy, there is less rocks, but that's more to help walking on even ground, the boat only slides on the sliders.
Marc...
PostPosted: Thu May 31, 2012 8:16 pm
Thanks for your help guys. Great suggestions. The trailer is a full size trailer that has these cradles Matt. Nice ramps also. New to Hobie ownership, we feel very good about our H 20 purchase and this support forum, we will have more questions as we go!
Any suggestions as to the Serial numbers? Ends in 900 is that 99, 2000 model?
H 20 Miracle 808
PostPosted: Fri Jun 01, 2012 9:10 am
Yep. Built is late 1999 as a 2000 model year.
http://www.hobiecat.com/support/articles/archive/?src=http://2010.archive.hobiecat.com/support/warranty/sailserial.html
PostPosted: Fri Jun 01, 2012 10:27 am
That's right, Andy. I've heard that you may damage your boat if you try to sail up on a ramp with your boards down. Do you know of anyone that tried to do it that way? :P
Mark Van Doren
San Juan 28
PostPosted: Fri Jun 01, 2012 2:51 pm
Also hear that not removing the mast pin can lead to excitement
H 20 Miracle 808
PostPosted: Fri Jun 01, 2012 6:25 pm
The only time not removing the mast pin is a problem is if you break a shroud and the mast comes down. The mast base will either rip the ball off the dolphin striker post or dent the hell out out of your front crossbar or both.
Under normal sailing conditions, leaving the pin in the mast base is not a problem. That is actually how the system was intended to be used.
