It is currently Thu Apr 18, 2024 3:23 am
 Post subject: Getting Maximum Speed...
PostPosted: Mon Nov 20, 2006 11:12 pm
So my brother (the infamous Captain Noah) and I have an H20 and a little sister. And we are wondering if in stronger wind we ought to bring her onboard to keep the boat down, as the two of us have to sheet out if we want to avoid capsizing. The issue is though, will we get more speed by sheeting out or by having the extra weight and keeping the sheets in?
PostPosted: Tue Nov 21, 2006 8:19 am
Travel out, sheet in, yank the downhaul and go as (censored) fast as you can! Leave the girl on the beach, she'll get hurt on the 20 in big wind.
PostPosted: Tue Nov 21, 2006 8:37 am
In de-powering the 20 we've been taught this progression, we're a light team and have used it a bunch to "calm the monster".
After double trap and max downhaul, then derotate the mast, then travel out the main.
It's a fun with boat with two on the trapeze and one driving, but I'll agree with Chris. When adding weight the boat will ride lower in the water and you'll being going so damn fast when you slam a wave with the front beam someone's going flying. :shock:
You guys be nice to your sister :wink:
Fleet 297
 Post subject: Heavy wind
PostPosted: Tue Nov 21, 2006 8:58 am
If you are still overpowered after dropping the traveler a few inches, consider pulling you daggers up about 4 inches. It will make a noticeable effect in helping to keep the boat down. Your upwind sailing ability will hardly suffer, if at all.
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
PostPosted: Tue Nov 21, 2006 4:57 pm
thanks for the input. how does the daggerboard trick work? and on that note, as anyone rigged a positive support system for the daggerboards to hold them up part way? i've seen this on a few other cats in our club, and have thought about installing something on our 20. i mean, whats a few more lines, anyway?
PostPosted: Wed Nov 22, 2006 7:17 am
Trick?
They (the boards) create lift, reduce that total area underwater by, as Trey suggests, pulling them up a bit will depower and settle the lifting hull.
We like the carpet in our trunks as the only means to support the boards. Is kind of a (censored) some times (hard to pull up) but have no added clutter.
Fleet 297
PostPosted: Wed Nov 22, 2006 8:37 am
I need to find ways to power my girl UP more. Its gotta really be blowing for me to be too overpowered, and usually the after the down haul is exahusted, I travel out a bit and I am good, but its in the moderate air I want to get her up and can't. I would think it was our weight, but 325 on a 20 is not too much. I can't figure it out. We usually have all the boat speed we need too going up wind. There are a million tweaks on this boat that is for sure.
PostPosted: Wed Nov 22, 2006 11:46 am
You probably don't want to hear what I have to stay, but first off 325?
Paul and I weigh between 305 & 315 depending on what he's spending money on (college kids!) You sure that 325 is right? You and Reagan?
In light air crew weight makes no difference. In heavy air you have the advantage. In moderate air I think a lighter team definitely has an advantage on this boat.
Match/set your main sail luff curve to the mast (prebend & spreader rake) and then leave it alone. Use outhaul to create more draft and power in your sail.
With the old cut, fuller E-P main our mast looks like a banana. With you're newer flatter cut sail I'd expect your mast to look more normal, without a tremendous amount of bend or rake.
Fleet 297
PostPosted: Wed Nov 22, 2006 12:10 pm
Me and Jordon. Reagan has a girlfriend now, and races 16 with her.
Thanks for the help. I look forward to pummeling you repeatedly on the water in the spring.
cw :lol:
PostPosted: Wed Nov 22, 2006 12:23 pm
North Central Area Championships 8)
Clear Lake, Iowa
May 19 & 20, 2007
Looking forward to it :D
Fleet 297
PostPosted: Wed Nov 22, 2006 9:30 pm
John Mid winters east in March? I hadn't thought of pulling the boards up some to depower, will have to think about that some.... Maybe we can talk Chris into going. Tom :D
Tom & Nancy Page H20 803
PostPosted: Fri Nov 24, 2006 7:46 am
Ya Chris,
Want to escape from the doldrums fo the high prairie in the dead of winter?
Mid-Winters East
St. Andrews Bay Yacht Club
Panama City, Florida
March 9th, 10th, and 11th, 2007
You've gone down for "schooling" before, haven't you? I think there is just a few 20's down there so we should be able to meld in and not look like total incompetents :o
Four certain and four maybe Div 14 boats.
Get some Div 7 boats and let's do it :)
You NEED to travel to three corners of the US in 2007.
Fleet 297
PostPosted: Sat Nov 25, 2006 8:39 pm
OK, I know we've completely destroyed this thread with personal chit-chat (SORRY) but I think we need to mention one other depowering item.
pasdnous,
Does your 20 have a seven hole adjuster at the top of the forestay?
This allows more mast rake than the stock setup which also settles the boat quite a bit.
cw, When is TW getting a 20? :twisted:
Fleet 297
 Post subject: 7-hole adjuster
PostPosted: Wed Nov 29, 2006 2:59 pm
no longer. we put the roller furler in and took it out, i think...
