It is currently Tue Jan 16, 2018 1:14 am
 Post subject: Footstraps
PostPosted: Mon Jul 30, 2007 6:25 am
Has anyone installed footstraps behind the rear x-bar? I'm assuming you can just drill two holed and use a bolt with a locknut and a few washers. And I was thinking seal it with some marine sealent should be good to go. Not sure if anyone has tried this. thanks.
PostPosted: Mon Jul 30, 2007 6:39 am
We reinforced the connection to the hull by using a two screw plate that had a corresponding plate for inside the hull.
PostPosted: Thu Oct 18, 2007 2:16 pm
I just added them to my tiger. order the ones with a backing plate DaKine is what i used seal them with marine sealant and enjoy the ride
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
cron
