It is currently Thu Apr 25, 2024 4:19 pm
 Post subject: Mast Issues?
PostPosted: Sat Feb 04, 2012 10:33 pm
I want to go to a lot of events this year, but have an issue with my two masts.
The mast I have with a comp-tip has decent corrosion around the mast rotator.
And the mast I have that is perfect has no comp-tip. If I show up with no comp-tip mast will anyone say anything?
Also I don't want to switch the comptip around because the all alum mast turtles slower and I like to live the by the motto, if it ain't broken don't fix it.
Ill show up with both masts anyway.
Some insight please?
Sail # 10505 or 277
Image Image
 Post subject: Re: Mast Issues?
PostPosted: Sat Feb 11, 2012 4:00 pm
No worries !!! Get that cat on the water! Already have someone with a solid mast in the group,no one seems to really care.Div.2 is a great group of people. I really hate the comp tip B.S. Wish I had a solid mast to.......
PostPosted: Tue Feb 14, 2012 9:19 pm
I sailed last year in div 2 and 3 with a solid mast. Everyone was very supportive and they really didn't mind. But.....things might have been different if I had been passing them (but that wasn't an issue last year). :oops:
I wouldn't waste my time with the other mast especially if the corrosion has made it unsafe. The only place you will be called on it will be at the Nationals in Mojavi if you plan on racing there.
The 18s are growing. Please bring your boat out!
H18 '85
H18 '89 "Knotty Passion"
H20 '96 "20/20 Vision"
Fleet 259 Central Coast California
PostPosted: Fri Mar 02, 2012 8:44 pm
Hello jmecky,
First can you post a picture or the corrosion?
Does your comp tip mast have the reinforcement plates mounted to the mast around the mast rotator bolt?
Bring it out with either mast and sail it like you stole it!!!
Cork Guy H18 sail#20
Corkguy H18, Tiger, Wildcat
PostPosted: Mon Mar 12, 2012 12:13 pm
Show up and race with either mast, and if you start winning races we'll handicap you by surreptitiously unscrewing hull plugs, loosening shroud ring dings, and slicing tramp lacing only 4/5ths of the way through, that way you won't worry about having the right mast.
PostPosted: Thu Apr 26, 2012 5:45 pm
Jmecky,
NOR has been posted for WET -N- Wild Are you in??? Pick a mast.....
NOR May 12 - 13 http://www.div3.hobieclass.com/site/hob ... OR12-1.pdf
Skipshot and I have entered. Mark, Ryan and Scott are also supposed to attend. The Water is Warm, the Beer is Cold and you can't get swept out to SEA!!!
Registration is open https://www.regattanetwork.com/clubmgmt ... ta_id=5215
Take Note: there is a $20 late fee if you enter after May 5th.
If you need H18 cup sticker for your jib just let me know.
Cork Guy H18 going for a div 3 three-peat!!!
