It is currently Mon Jun 26, 2017 10:53 am
 Post subject: Spinnaker Blunt End Cap
PostPosted: Tue Aug 12, 2008 5:06 pm
:shock: I just recently became aware of this new requirement.
12.2 Only bowsprits supplied by a HOBIE CAT
COMPANY are class legal. The bowsprit shall
have a blunt end cap fitted.
The bowsprit shall
be fixed on the longitudinal centre line of the
boat as provided by the manufacturer. Supporting
wires/lines may be shortened, lengthened,
mounted and/or rigged in any manner. Additional
blocks/cleats for spinnaker running gear
and jib luff control as well as snuffer type systems
may be mounted on the bowsprit.
So, wanting to do this right with NA's only a few days away, I looked it up.
What is a blunt end cap anyway?
http://www.urbandictionary.com/define.php?term=blunt :shock:
How am I going to get one of those through customs? :lol:
2003 Tiger - Don Atchley
PostPosted: Tue Aug 12, 2008 6:02 pm
I have it from a solid source that you can pick up one of those when you get over the border, eh!.
Sail Revolution
Join us on our new FB Page!
PostPosted: Tue Aug 12, 2008 7:52 pm
The stock end cap as supplied by Hobie Cat is a "blunt end cap" for the purposes of the class rule.
The rule is meant to prevent "spearing" injuries caused by a cut away pole.
PostPosted: Tue Aug 12, 2008 9:11 pm
I lost mine. Same with the boom. I should replace those, it just looks rugged with out them. Like it should be parked outside of a rusting trailer home next to a 84' Camaro in primer grey.
PostPosted: Tue Aug 12, 2008 9:58 pm
Tape it inside the spin pole, then cover it with the blunt cap
Tiger 947/2364
PostPosted: Wed Aug 13, 2008 7:13 am
The rules dont say it has to be the original HC blunt cap, so probably a piece of cork should do, but you cant smoke it.
PostPosted: Tue Apr 21, 2009 11:04 am
Is this rule still applicable under the new ISAF rules? I wanted to run a open cap that allowes the tack to run out the end of the pole. It is a rounded aluminum piece similar to the Infusion.
Will this be class legal?
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
