It is currently Thu Mar 23, 2017 11:57 am
 Post subject: trampoline
PostPosted: Fri Mar 27, 2009 1:56 pm
My Tiger is 10 years old and my trampoline is a 3 piece one and is in a bad shape. Is Hobie still making the 3 piece trampoline? the reason I ask is because i do not live in the USA and I had some dificulty in finding in the USA.
Does the new one piece works in my boat?
Thanks for the attention
 Post subject: Re: trampoline
PostPosted: Mon Apr 27, 2009 1:31 pm
I cannot believe no one has replied to you yet. Sorry about my delay.
I believe the one piece trampoline will work fine. The front and back crossbars are mounted exactly the same distance they always have been. You will have to add four eye straps to the cross bars where the wire, I use line, attaches the sides for and aft. The front will slip into the same track your old one did and the back is laced up the same way. Some do not like the new tramp compared to the older one. I like it just fine.
Later,
Dan
PostPosted: Mon Apr 27, 2009 3:06 pm
Hobie Tech / Moderator
You can still get a two piece tramp that will have the rear lace strip - same as your boat has now. Just order it from a Hobie Dealer. Specify when ordering you have the old style tramp attachment so we fill the order properly.
PostPosted: Thu May 21, 2009 3:51 pm
Dan
Thank you very much for your reply I just got back from the USA and Scott Hardy from The boat locker was most helpfull in getting the right one.
PostPosted: Fri Sep 25, 2009 6:36 pm
Hi
I'm new to the forum and have a related question. I have a 2000 Tiger and the tramp is one piece but slides in slots in the hull unlike the newer ones. Is this type of tramp still available. Also is it possible to have reinforcements heat welded in place on my existing tramp and if so where?
Thanks Scott
PostPosted: Thu Oct 08, 2009 12:07 pm
according to Jacques post above it is still available. call your dealer.
