It is currently Tue Mar 28, 2017 11:37 am
 Post subject: Anchor pins
PostPosted: Thu Jan 13, 2011 8:16 am
hello everyone just a quick question about the anchor pins for the shrouds on my tiger they have moved out of place and am wondering what holds them in place and do i have take them out to sort the problem out thet feel like there is a threaded part on the pin but do not know if its into a threaded plate or not any help would be great
thanks
paudie
 Post subject: Re: Anchor pins
PostPosted: Thu Jan 13, 2011 1:43 pm
The pin threads into the hull. I'm not sure what they thread into, if its a plate or a plug of sorts. If the threads are messed up on the female part I'm not sure what you can do other than run a tap in it and clean up what is left. Or, cut out whatever it threads into and replace it.
PostPosted: Fri Jan 14, 2011 1:21 pm
On the Tigers there is a plate glassed into the hull. Accessable from the front port hole cover. the pin screws through the plate.
I will try to get a decent pic.
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
PostPosted: Fri Jan 14, 2011 6:12 pm
Thanks for your help guys can not get a good look at it inside the hull will thread them back into the hull and see what happen
paudie
PostPosted: Fri Jan 14, 2011 11:55 pm
make sure to put some Sika Flex on the bolt oand in the hole before you thread it in. keeps it water tight.
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
PostPosted: Sun Jan 16, 2011 6:58 am
Get one of those small teloscopic mirrors at an automotive parts store...should be able to see the plate then.
Tiger 1047
Users browsing this forum: randii and 1 guest
