It is currently Thu Nov 23, 2017 2:24 pm
 Post subject: Mainsheet Taper
PostPosted: Tue Jul 19, 2011 6:29 pm
Hello everyone
I want to taper my mainsheet on my tiger and was looking for the lent of the taper and where the splice should start i am running the 9:1 purchase system
Paudie
 Post subject: Re: Mainsheet Taper
PostPosted: Fri Jul 22, 2011 11:26 am
Start by marking your current sheet mid way up between the two blocks.(between the cleat and the top block) This needs to be marked at the Block to Block max steating position. You will want to bury atleast 18 inches into the bigger line. Also give yourself a couple extra feet till your sure on length. Undo your blocks and you have a sheet to measure to get your new lenghts.
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
PostPosted: Fri Jul 22, 2011 4:41 pm
Thanks for your advise Rich i will look into it in the morning
Paudie
