It is currently Thu Nov 23, 2017 9:25 pm
 Post subject: Old style Tiger tramp?
PostPosted: Wed Aug 03, 2011 7:36 pm
Does Hobie still have the old style Tiger tramps for sale?
Floyd
00 Tiger
http://www.HobieFleet33.com
10 Mile Surfside, Texas
Join us on our Facebook group: Surfside Sailing
PostPosted: Fri Aug 05, 2011 8:27 am
There are two "old style" Tiger tramps.
The oldest attaches to a slot in the hull on the sides.
The other one isn't attached to the hulls, but goes under the front x-bar.
The latest edition goes over top of the front x-bar.
PostPosted: Fri Aug 05, 2011 8:33 am
Mine is the oldest then it goes into a slot on the hull sides so I guess to keep that set up i will need to have one made?
Floyd
00 Tiger
PostPosted: Mon Aug 08, 2011 7:38 am
You can retro-fit the "Type II" tramp. It's a lot easier to get on and off. The one that threads into the track can be a bear.
PostPosted: Mon Aug 08, 2011 2:29 pm
This one require me to add the rivets to my rear beam and get the fiberglass rod?
Floyd
00 Tiger
PostPosted: Mon Aug 08, 2011 4:45 pm
You must have the original "Type 0" tramp. I've only seen one of those with a lacing strip in the rear.
Short answer is "yes" - you would need to use the studs/fiberglass rod to retrofit any of the other tramps.
PostPosted: Mon Aug 08, 2011 8:11 pm
Thanks Matt I emailed Hobie to see if they still have any of old tramps for sale if not I may see what the price difference would be to retrofit vs having SLO sailing make me one like the old one.
Floyd
00 Tiger
PostPosted: Sun Sep 11, 2011 9:33 am
I had SLO make me one based off the one that came off and that allowed me to make a few tweaks I will post up some photos once its installed.
Floyd
00 Tiger
PostPosted: Mon Sep 12, 2011 5:03 am
What did it run you? My 02 Tiger tramp is starting to tear at the halyard pocket :(
What mods did you do? Id like to have a few more grommets for control lines, mast rotation etc. Id love to see Picts when you get it!
Blair T
I love these calm moments before the storm, it reminds me of Beethoven...
'02 Hobie Tiger USA 1152
PostPosted: Mon Sep 12, 2011 6:29 am
I had SLO increase the pocket size, add the lacing grommets down the one side, put two more grommets by the mast base so I can run the downhaul lines under the tramp in the future. It was $310 add shipping and Teflon stitching it came to $370. I will post up some pictures this week I started to put it on yesterday but I didnt have any lacing rope to do the side but the front to back fit is perfect once I lace the side up it will fit nice & tight.
Floyd
00 Tiger
PostPosted: Mon Sep 12, 2011 7:38 am
That sounds very reasonable, definitely shoot me a picture, I'm probably going to have them make me one too
Blair T
PostPosted: Mon Sep 12, 2011 8:37 am
Hobie Tech / Moderator
Yes - we still offer the original style tramps, order from any Hobie Cat dealer (specify if it is the one piece or two piece) - the two piece entered a slot in the rear beam, the one piece was a later version that had the button on the rear beam and the fiberglass rod same as current style - but both have bolt rope in the sides of the tramp which slide into the inter graded tracks built into the hulls.
Current style tramps can be added - but it require the addition of hardware and the addition of the rear lace rod (which we don't have in stock)
The tramps however, we do carry.
