It is currently Sat Jan 20, 2018 5:40 pm
 Post subject: Wildcat dagger uphaul
PostPosted: Mon Jul 16, 2012 6:04 pm
What is the correct size line for the up haul and what size hole must be drilled.
Ahab
PostPosted: Wed Jul 18, 2012 7:19 am
Got the hole drilled (5/32) but looks like I need a counter bore or recess to fit the square knot?
worked great last night on the shake down, two races last night and took a 4th and a 1st but pulled too hard on the last down wind leg and the half hitch pulled apart letting the board come almost all the way up!
Any advice? Ahab
PostPosted: Wed Jul 18, 2012 8:34 am
Hobie Tech / Moderator
The other JB told me...
"use 5/32" amsteel line and drill a hole slightly bigger than 5/32". Tie off with a figure 8 knot. Works for me.
Noticed you haven't registered for the Worlds yet...pre-reg deadline is August 1. It'll cost $150 more after that."
Jacques Bernier
http://www.hobiecat.com/
