It is currently Fri Feb 22, 2019 10:34 am
PostPosted: Sun Jun 05, 2016 1:47 pm
I realized I should probably update you guys on how it turned out.
I did the well repair, then glassed the cut-out foam plug back in with a wood clamp I made.
Then I feathered the foam, and filled it with fiberglass.
Sanded and Gelcoated
The gelcoat spray gun was a nightmare(supposedly a $1500 dollar setup, maybe we just didn't know how to use it). However, the gelcoat was not hard to work with at all, so we ended up rolling onto the repairs and are sanding/polishing smooth into the existing factory coat, and that worked great. At some point in the future I'll try to get it all to the same thing. The foils I'm converting to a hard 2-part epoxy paint.
How did it turn out? Well, you tell me.
2003 Hobie Fox, Hull #38, sail #101.
1981 Hobie 16, sail # 79737. 1981 Prindle 16, sail # 4544
Rear Commodore, Utah Lake Yacht Club
PostPosted: Thu Jul 07, 2016 9:57 am
Do the photos show up for others on this forum? Would love to see pictures of this repair but they aren't appearing.
PostPosted: Thu Jul 07, 2016 10:10 am
They work fine for me but here are the direct links if you would like them for the stuff on page 2. Let me know if you want any of the older stuff.
Access hole repair:
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 9849_o.jpg
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 7739_o.jpg
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 6188_o.jpg
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 0430_o.jpg
Gelcoat
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 5537_o.jpg
https://scontent-lax3-1.xx.fbcdn.net/v/ ... e=57D20B1A
All put back together (Early June, 2016)
https://scontent-lax3-1.xx.fbcdn.net/t3 ... 7690_o.jpg
https://scontent-lax3-1.xx.fbcdn.net/v/ ... e=57C826C8
