It is currently Wed Apr 24, 2024 6:29 am
 Post subject: Wild Cat Jib Battens
PostPosted: Fri Feb 19, 2016 6:10 am
The Hobie "Illustrated Parts Guide" doesn't specify part numbers fot the Wild Cat jib battens.
Can someone tell me the part numbers (if they exist) or the specifications of these jib battens so I can order replacements?
Wildcat.
Discovery Bay, Hong Kong.
 Post subject: Re: Wild Cat Jib Battens
PostPosted: Fri Feb 19, 2016 12:52 pm
We don't have these as a separate item - but most any sail maker can supply a jib batten for you. This would need to come from the sail maker in Europe to be the exact fit - w don't stock this item since it's very rare if ever that they are needed.
Jacques Bernier
http://www.hobie.com/
PostPosted: Sat May 21, 2016 4:07 am
I can supply RBS battens if your still in need.
2010 AHPC C2 #218
