It is currently Sat Nov 18, 2017 2:11 am
 Post subject: jib traveller position
PostPosted: Wed Oct 03, 2007 1:30 pm
I wonder how you guys adjust your jib traveller with the self tacking system. I have not quite yet found the right angle for each wind condition. For light winds (say up to 8 knots) I set it about 10cm (4 inches) inwards from the most outward position. For winds over 16 knots I will let it all the way out, and use some settings in between for the other conditions. How do you set this up?
PostPosted: Wed Oct 03, 2007 7:47 pm
I had the good fortune to get Darren Bundock to have a look at my Tiger over the weekend and he said that they keep the jib traveller centered over the second post all the time - never vary it.
Kyle Tiger T 1893
PostPosted: Thu Oct 04, 2007 6:38 am
This is interesting! He didn't by the way tell you his mast rake setting? :))
PostPosted: Thu Oct 04, 2007 4:41 pm
He did.
Basically using the transom as a guide. Its a 4" (100mm) band down the transom starting 2" (50mm) down from the top, for light air down to the middle set of screws holding on the gudgeon plate for heavy air.
I had mine half way between these two points and the boat was very stable in over 25knts.
Kyle Tiger T 1893
PostPosted: Thu Oct 04, 2007 10:24 pm
This really helps a lot to get the boat set up right! Thank you very much!
PostPosted: Thu Oct 04, 2007 10:30 pm
No worries - we all need help with the Tiger its such a beast with so much power, its hard to know what to fiddle with next
Kyle Tiger T 1893
