It is currently Fri Jan 19, 2018 1:29 am
PostPosted: Sun May 11, 2008 8:53 pm
Does anyone know what model Loos guage was used to come up with the numbers that Mich Booth references in his 2006 tuning guide.
I assume it was based on a standard Loos Tension Gauge and not a Loos Professional Gauge. The reason I ask is that guys in our fleet are getting readings of 15 points difference between the two different gauges.
We are running 36 for the diamond tension on the standard Loos and doing really well with the leeward diamond just starting to go slack in moderate breeze - so that leads me to belive that we are OK using the standard guage.
If anyone knows and could let me know it would be appreciated.
Cheers,
Paul
PostPosted: Sun May 11, 2008 11:44 pm
A friend helped me measure mine and we are running 36 on what I'm pretty sure was the pro gauge. I think for the standard you should be somewhere in the 40's..?
I'm in the process of reconfiguring my computer so I can't open PDF's yet, but scroll down to the "Taming your Tiger" thread and check that out; there's a part in there about this.
Tiger 947/2364
PostPosted: Mon May 12, 2008 9:19 am
I use somewhere around 46 or 47 on the silver colored Loos Gauge, that is about 700 lbs. The black one does not have a scale that goes that high so I have not used it as much. I should put in on the diamonds after I adjust with the silver so I get a reference point.
Dan
PostPosted: Mon May 12, 2008 10:20 am
Dan
So what I am seeing is that on the standard gauge (silver), 36 equates to about 15 on the Pro (black). I have generally been tuning by the silver loos, mainsail shape, tip deflection and the tension of the leeward shroud. We have been quick so far but I may bump the rig tension up a few turns based on your input.
Thanks...
PostPosted: Tue May 13, 2008 5:16 pm
Cheers,
Paul
They are based on the black Loos gauge - which goes up to 42 (answer to life, the universe and everything).
Chris.
2008 Hobie Tiger
PostPosted: Thu May 15, 2008 9:15 am
Chris.
Another Douglas Adams fan!
