It is currently Fri Jun 23, 2017 9:28 pm
 Post subject: Tiller grip
PostPosted: Thu Jan 22, 2009 6:19 pm
Overhand grip or underhand,which do you use?These are two of the top 16 sailors in the world using different grips.
Hey its a cold night here in Thunder Bay.
PostPosted: Thu Jan 22, 2009 6:22 pm
Kinda neither. I've got one of those cork balls and I let the stick out in between my middle finger and pointer finger. I hang onto it like a shifter.
PostPosted: Thu Jan 22, 2009 8:02 pm
I'm an underhander that wishes I would have learned overhand, it looks cool and all the EU & AU sailors seem to do it...but old habits are hard to break :roll:
Check that Euro main with reef points. 8) along with the solid AL mast
Sheet In...Max Out
www.fleet297.org
PostPosted: Thu Jan 22, 2009 8:51 pm
Overhand, what do you think you are sailing? A Laser?
PostPosted: Fri Jan 23, 2009 6:16 am
It depends . . .
Sailing upwind, laid out on the wire - overhand
Upwind, light air - two-finger underhand
Downwind - underhand, unless the tiller starts getting whacked by waves, then overhand.
Typically overhand gives you more feel, but less power. The rudders have to be balanced (almost no helm)
Underhand gives you more power (strength to steer), but less "boat feel".
PostPosted: Fri Jan 23, 2009 9:24 am
Had a great discussion with Pat Porter about tiller grip at this years N.A's.He had been to a Gavin Colby clinic and said Gavin and was adamant about steering from the trap with an overhand grip.I agree with Matt you need almost neutral helm to do this.
PostPosted: Fri Jan 23, 2009 3:08 pm
This reply from Pat Porter(if you ever have the chance to meet this man,tap into his wealth of knowledge on racing the 16)
"Mike, I read the forum this morning. Yes I have some definate feelings on how the tiller is best held. After many years of holding the tiller underhand I changed to the overhand position about five years ago. I wish I had always held the tiller overhand because it would have prevented many tacking problems and flips that had ocurred during my 25 years of holding the tiller underhand.
Let me explain when I sail overhand and when I still sail underhand and why. Overhand, it allows you to rock and twist your body forward bringing your tiller hand in front of your body. Thris provides more steering control, better boat balance more flexable body possition inrelation to the crews possition. You can see what I mean by looking at photographs of teams while they are double trapping. It is especially evendent on the Tiger. Overhand greatly simplifies tacking. I do not cleat the main during the tack. Prior to the tack I transfer the mainsheet to the tiller hand, two fingers and thumb hold the tiller two fingers hold the mainsheet. As I come in off the wire, I rock the tiller up as I press it forward turning the boat through the tack. Rocking the tiller up maintains the the same sheet lenght between my hand and the blocks which holds the sail tight untill I pass head to wind at which time I release the sheet change hands and spin the tiller and call the jib crossing.
Underhand; I use the underhand position when I round the weather mark. As I approach the mark I change from overhand to underhand. (I have frequently dropped the tiller doing this because I just throw it up and regrab it) I then transfer the uncleated mainsheet to my tiller hand. This time I hold the mainsheet and tiller together griping with my hand. This allows me to let the mainsheet slide through my hand to let the main out as I round the mark. While I'm doing this I pull my left arm back to steer the boat around the mark and use my right hand to grab the trap handle to come off the wire.
Now Gavin has a different approach to the weather mark rounding. He holds the tiller overhand and usually does not transfer the mainsheet. He stays on the wire untill the rounding is almost complete. As the boat comes around, from the wire he steps on the REAR crossbar and walks onto the tramp from the back of the boat. He then colapses and moves foreward on the boat for the downhill run. I sat on a press boat at the weather mark in Mexico and watched him make this move over and over. He is the only person that I know that rounds quit like this. Also one day on the beach he tryed to teach me how to do it. I never could.
A couple of things that I should also mention. My boat has NO weather helm but I don't think that should make any difference in how you hold the tiller. When I go out on the wire I hold the tiller in one hand and the mainsheet in the otherand I don't use the trap handle. When I come in off the wire I hold the tiller and mainsheet in one hand and I use the trap handle with the other.
So there you go. Hopefully this will stimulate some thought."
These photo's illustrates what Pat was talking about when he mentioned a more flexable body posistion.All the top sailors sail with this torqued upper body.As you can see they are taught at a young age.
PostPosted: Sun Jan 25, 2009 11:39 am
Been using the overhand more & more over the last few seasons. The zoot factor is very high!!! :lol:
PostPosted: Mon Jan 26, 2009 6:32 am
Zoot?
