It is currently Sat Sep 26, 2020 1:16 pm
PostPosted: Tue Jul 28, 2020 6:06 am
Daniel Haglund,
I just checked my mast ball and it measures 64 mm or 2 1/2" top of crossbar to top of ball
On my parts boat that measurement is 68 mm or 2 11/16"
Your looked to be about 74 mm
So my boat at 64 mm is most likely as low as it can be :wink: ....
Bill 404 21SE
PostPosted: Fri Jul 31, 2020 2:33 pm
Bill 404 wrote:
Daniel Haglund,
This good information! Thanks. Next time I will probably just make sure the ball bottoms out and then just make it stay in place using epoxy glue.
Hobie Cat 21SE #376
PostPosted: Mon Aug 03, 2020 9:54 am
When I replaced mine, I kept thinking "how much further will this thing screw on???" It stops eventually. You want it to bottom out without forcing too hard. That way, it should take a lot of stress off the threads and put it on the end of the striker rod. At least, that's my reasoning... I just used several wraps of teflon tape to the point it was a real snug, just at hand-tighten-ability to screw it down, then used a strap wrench to give it a snug at the end.
Have NO IDEA what the official Hobie method is...
ChuckC
H21SE- 408
